- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi John!
Once again a big thanks for your help!
At any rate, similar to my video, I created a new A0 block in modelspace that shows the outline of the page edges as well as the margin.
I then created a new PageSetup and adjusted the margins in the PC3 to 10mm for the selected A0 size.
Next, I created a new layout with the viewport set to the resulting plot (minus the margins).
I used Alignspace to align the margins of the block with the corners of the viewport. I did this for each instance on a new layout.
I tried to follow your steps. The example.pdf file you created with the 7 pages is exactly what I needed. However I have lots of other files and need to do it there too. So I have to be able to do it on my own. I tried to figure it out what you said, but I was not able to replicate your steps. Would it be possible that you do a second screencast/video with what you did?
