TheCADnoob
en respuesta a: Anonymous
I would look into rebuilding your pdf printer https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Creating...
or you might be able to change setting like resolution in your current one to try to alleviate the issue.
Also you can look into thing in the other programs like mentioned here in this thread: https://forums.autodesk.com/t5/autocad-lt-forum/problem-pdf-print-generates-strange-lines-over-hatch...
CADnoob
