594 Vistas, 2 Respuestas
Problems when using 'place' in Photoshop after exporting to 'eps'
Problems when exporting from 'cad' to 'eps' using 'postscript level1', then importing from 'photoshop' to 'place'
This is normal when you open the file in 'photoshop' with 'open'.
(photoshop open)
The problem is that when you load the 'eps' file of the drawing into the 'place' in the 'open' task pane, a polygon line appears as a sample screenshot.
The polygon line is empty.
(photoshop place)
Matches the polygon line that appears when the corresponding 'eps' file is opened in Illustrator.
(illustrator open)
Due to the nature of the job, the new drawing is repeatedly loaded from 'psd' file to 'place'.
In this case, the 'hatch' area filled with 'solid' is not working because the polygon line is not shown like all the sample photographs. I would like to know if there is a solution.
It did not happen in the 'autocad 2011' and 'photoshop cs3' versions.
Etiquetas (5)
