john.vellek
en respuesta a: Anonymous
HI @Anonymous,
I apologize for the delayed response. We just had a bank holiday in the States.
At any rate, similar to my video, I created a new A0 block in modelspace that shows the outline of the page edges as well as the margin.
I then created a new PageSetup and adjusted the margins in the PC3 to 10mm for the selected A0 size.
Next, I created a new layout with the viewport set to the resulting plot (minus the margins).
I used Alignspace to align the margins of the block with the corners of the viewport. I did this for each instance on a new layout.
I have included my version of the file, the resulting PDF as well as my PDF.PC3 and PMP files.  The PC3 file needs to be stored in a location similar to :
C:\Users\vellekj\AppData\Roaming\Autodesk\AutoCAD 2017\R21.0\enu\Plotters
And the PMP file needs to be stored in a location similar to:
C:\Users\vellekj\AppData\Roaming\Autodesk\AutoCAD 2017\R21.0\enu\Plotters\PMP Files
John Vellek
