- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> I am receiving some drawings where items and texts
>> are jumbled and do not display correctly
How can we know which text objects you are referring to?
>> I have tried to download the object enabler
Object enabler for which product?
I see a product "VisionREZ" from company "ITWBCG" as message in the proxy-warning, but that's just one object.
It also looks like AutoCAD Architecture or maybe MEP was working on that drawing.
And I'm missing the XREF ![]()
I have now opened your drawing with AutoCAD 2017, run command -EXPORTTOAUTOCAD to DWG-2010 format ... opening this drawing shows the same text as your uploaded drawing (or I missed something).
Please find the exported dwg attached.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Alfred,
Thank you so much for reaching out. I am a bit confused that you are not seeing the objects I am. It must be that Architecture and MEP is not compatible with my AutoCad. I just have not had any problem in the past. Also I am assuming by your comment that the object enabler is not what I need. It is just that when I open the drawing a screen comes up telling me objects will not be displayed properly and to download the enabler
The exported drawing you sent has saved me!! Converting to 2010 did the trick.
Again, thanks so much for reaching out.
