john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I looked at your file and found that it consisted of 8 blocks. I assume that it was somehow exported from Illustrator and they were created in the process.
I exploded them and then used JOIN to connect all the lines.  I then noticed that the color of the lines was set to 255,255,255 which is a color you will not see if plotting on a white background. I changed the color to BYLAYER so it will take the color of the layer that it is on.
I switched to layout view which is ideal for printing and plotting. I zoomed into the object in the viewport to maximize its size. I also put the viewport frame on its own layer and set it to non-plot.
Lastly, I used plot and selected the papersize and PDF driver.  Let me know if this gets you started or if you need more detail.
John Vellek
