- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
DMFrazier,
1) Thank you for your comfirmation on this (i did check it with R2011 & R2015 - work the same)
2) i do not use arg file i do duplicate (with c# program) the default profile "<<Unnamed Profile>>" or any other one that is currently set
then call autocad with startup switches (to run script) as i mention before
either way it works bad the same.
3) (Note that starting AutoCAD using the /p switch can set an existing profile current, but it cannot (does not) import a profile from an ARG file.)
are you saying that if the profile already exist? and you call autocad with /p it will set it current but will not override the existing profile?
4) have you notice when switching to another profile autocad does copy the starup suite list of the current profile to the target profile?
and as i mention, it also copies other settings along (free on the house
Moshe
