dmfrazier
en respuesta a: Moshe-A
You are correct: the Startup Suite contents are stored in the profile, in the registry, and this information is included in the ARG file when a profile is exported.
You are also correct that the Startup Suite contents do not appear to change correctly when switching from one profile (existing in the registry) to another profile (existing in the registry). (This is based on my seat of 2014.)
(Note that starting AutoCAD using the /p switch can set an existing profile current, but it cannot (does not) import a profile from an ARG file.)
It also appears that importing a saved profile from an exported ARG file, over-writing a registry-stored profile of the same name (if it exists), also fails to change the Startup Suite contents as you would expect it to based on the lines in the ARG file that (supposedly) store that information.
Looks like a "bug".
