1077 Vistas, 5 Respuestas
Print/Export model in dxf to pdf with custom margin?
This is connected to my old problem. I was not able to implement the suggested solution in the old thread, so I now try a new way. That is I use Adobe (Reader or Illustrator) to tile the complete file into different A0. This works, I sent it to a virtual printer and get a pdf file with 8 A0 pages (in my old thread I mentioned A4, but I now found a copyshop where I can do it in A0, so I have to have A0 at the end.)
This way works, however there is a big problem: In Adobe I cannot adjust the margin. The margin options cannot be set by adobe, they are somehow fixed. They are created when the pdf is created.
Therefore I now want to create a large pdf file from my dxf file with a specific margin (no need for tile or so, this comes later with adobe as I said). So I want to have my lines in a large pdf file where I can manually set the margin options.
I tried to figure it out and I saw that there is an option to use custom pages and there set the margins manually. However this does not work, since I am simply not used to Autocad.
I have now two problems:
I open my dxf file. First problem is that always a blank page is printed. Somehow my model is not in the right layout. So I have to somehow move my model to the print layout. I also googled viewports but could not figure it out.
I just tried to print it, so open my dxf file and click on the A symbol and click on print:
The result is an empty pdf, it does not contain my lines model?
Second how can I export it to a pdf (I think I have to use the dwg to pdf.pc3 plotter) with manual set margins - lets say 1cm top bottom right and left? I tried to use the settings of the dwg to pdf.pc3 plotter and define a custom page size with custom margin - but it does not work. (Also the final page size should be large enough that everything fits into. So my model is almos 2,5m times 2m. In a large pdf with that size everything should fit in. Would be good if this is somehow automatically done, because I have also other line models which have a different size. But I am also fine with manually entering it, although I do not know how to find out the size in autocad, but I can do it in Illustrator. But this is of course extra work.)
pendean
en respuesta a: Anonymous
>>>>..since I am simply not used to Autocad....<<<
>>>...but I can do it in Illustrator...<<<
The correct software for the job at hand most likely: AutoCAD cannot do 'everything' and as I try and follow what you want to do I believe that is correct.
john.vellek
Hi @Anonymous,
I looked at your file and found that it consisted of 8 blocks. I assume that it was somehow exported from Illustrator and they were created in the process.
I exploded them and then used JOIN to connect all the lines.  I then noticed that the color of the lines was set to 255,255,255 which is a color you will not see if plotting on a white background. I changed the color to BYLAYER so it will take the color of the layer that it is on.
I switched to layout view which is ideal for printing and plotting. I zoomed into the object in the viewport to maximize its size. I also put the viewport frame on its own layer and set it to non-plot.
Lastly, I used plot and selected the papersize and PDF driver.  Let me know if this gets you started or if you need more detail.
John Vellek
en respuesta a: john.vellek
Hi John,
Once again thanks for your support.
However I am struggling to achieve what I need.
The thing is as follows:
I have a dwg/dwf file which is quite large as you already noticed. Now I have to get this "into reality". First I wanted to split and print it with A4 as you know, then I wanted to split it into A0 since I came up with the idea of printing it in a copyshop and I thought I could split it with adobe reader or adobe illustrator, because I am not able to do it in AutoCad. However the problem with adobe reader and adobe illustrator is that when I send it to a virtual pdf (to send this pdf to the copyshop) the splitted drawings have no margin.
So I have my dwg/dwf which you know already.
So can you once again finally show me how in AutoCad, I can:
  • Split this dwg/dwf drawing into A0 pdfs (this will in case of this drawing likely result in 8 A0s, however I have also other drawings which are a bit smaller or larger)
  • Do it that way that the final A0 pdfs have a margin of 10mm.
I was unfornuately not able to put the solutions in the other thread together with this thread and find a working solution. So would be great if you can show me how to do this.
john.vellek
HI @Anonymous,
I apologize for the delayed response. We just had a bank holiday in the States.
At any rate, similar to my video, I created a new A0 block in modelspace that shows the outline of the page edges as well as the margin.
I then created a new PageSetup and adjusted the margins in the PC3 to 10mm for the selected A0 size.
Next, I created a new layout with the viewport set to the resulting plot (minus the margins).
I used Alignspace to align the margins of the block with the corners of the viewport. I did this for each instance on a new layout.
I have included my version of the file, the resulting PDF as well as my PDF.PC3 and PMP files.  The PC3 file needs to be stored in a location similar to :
C:\Users\vellekj\AppData\Roaming\Autodesk\AutoCAD 2017\R21.0\enu\Plotters
And the PMP file needs to be stored in a location similar to:
C:\Users\vellekj\AppData\Roaming\Autodesk\AutoCAD 2017\R21.0\enu\Plotters\PMP Files
John Vellek
Hi John!
Once again a big thanks for your help!
I tried to follow your steps. The example.pdf file you created with the 7 pages is exactly what I needed. However I have lots of other files and need to do it there too. So I have to be able to do it on my own. I tried to figure it out what you said, but I was not able to replicate your steps. Would it be possible that you do a second screencast/video with what you did?
