shelmer
en respuesta a: john.vellek
I'm looking at this again, and I think you are right.  Adobe is creating rasterized text, but doing a better job than DWG to PDF.  I do notice that the Adobe driver has a specific OLE object quality setting, separate from the typical DPI setting.  On my machine the Adobe OLE quality setting is at "Best".
I have also played with the resolution in the DWG to PDF driver as you suggested, and that make a big difference.  My issue is that we deal with a lot or air photos.  At 600 DPI, the PDF is an acceptable size, but at 1200 DPI, the email will blow up to un-emailable sizes, and the client becomes displeased.  :cara_con_una_leve_sonrisa:
