beyoungjr
en respuesta a: Anonymous
I am attaching another dwg for your review.
I created an accurate 3D solid model of your Sub Base and generated base views (ViewBase) and a detail view (ViewDetail).  ViewDetail was the command that you initially posted about and I wanted to show you a result with that usage.  I ignbored the pdf extractions that I performed for the 2D sample I sent last time, and I recreated true elements based upon the dimension data on your initial design.
I did not apply dimensions to the "A4 (2)" layout tab.  You can simply look over the views and use this file a reference if you elect to work in 3D at some point.  Remember that these base views are not in viewports and that dimensional data for this process must be on the Paper Space layout.
Cheers,
Blaine
Blaine Young
Senior Engineering Technician, US Army
