919 Vistas, 3 Respuestas
Converting from 3D to 2D
Hi there,
Previously I was able to convert any 3D view of an object into a 2D equivalent but since updating it seems I can only now do this if the section plane cuts through the object? But I don't want this as I want a view of the whole object.
Any ideas on what's going wrong here?
Vinayv4v
en respuesta a: Anonymous
Command : VIEWBASE
Here is what you need to know:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/AutoC...
Cheers,
Vinay Vijayakumaran
imadHabash
>> Previously I was able to convert any 3D view of an object into a 2D equivalent <<
what commands you getting used to ?
>> but since updating <<
what kind of updates ?
>> But I don't want this as I want a view of the whole object. <<
then you have to set your needed view then use FLATSHOT command and / or SOLPROF command from layout space.
Imad Habash
Erense
en respuesta a: Vinayv4v
True,
However, Viewbase is a command only available when the ModelDoc menu is loaded.
If the command gives an error:
Type Menuload
Click [ Browse ]
Browse to the support folder (where the main AutoCAD menu is too) and select the Modeldoc.cuix.
Click [ Open ]
Click [ Load ]
Click [ Close ]
Viewbase should be available now.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
