en respuesta a: Anonymous
hi gs:
I have an idea about your requirement. If you use ObjectARX to write a small plugin,  you can use a AcDbDatabaseReactor, to monitor whenever a leader entity added, then you can change the "Source Block" to your company's standard(can pop up a small dialog to choose which type), in spite of any default "source blocks". You don't even need to care about what the default source blocks are, because you don't need to go to "Properties" panel now.
If you don't know how to write an ARX plugin, we are honored to help you. Please do not hesitate to let us make this small tool for you, and it's totally free, :cara_con_una_leve_sonrisa:
