08-20-2017
07:47 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-20-2017
07:47 PM
If you find Ribbon tab in CUI, You can see "Tabs", It is one Ribbon tab such as the Annotate tab.
When you scroll down then you can see "XXX contextual tab" in "Tabs" such as Block editor contextual tab, It is When you use Block editor then change the another ribbon as automatically.
Also, You can see "Panels" that you edit command as one group at here.
Edited panel inserts into Tab.
In short, commands are collected and become one panel.
Panels are gathered and become one tab.
Tabs are gathered and become one Ribbon.
Therefore you can see pull down menu and button in the panel.
