Alfred.NESWADBA
en respuesta a: Anonymous
>> but, it is too fast and too blurry
YouTube needs a bit to be able to stream in full performance and so in high res.
You should see it clear when you step back to the start a few times (and to make it more easy I also attached the file now to the post)
>> Is there an audio?
Sorry no, but I guess as I'm not a native English speaker it's better you don't hear my broken English :cara_guiñando_un_ojo:
>> I don't know which Ribbon you're on
You need to see the layer-combo in the ribbon ==> there do a right-click and in the context menu use option "Add to quick access toolbar"
Then I started command _CUI to modify the width of the layer-combo in the quick access toolbar.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
