jeff3J5VE
en respuesta a: john.vellek
John, I attached a file with the issue.  At times today it was displaying properly.  I'd come back into the file at other times, and it was not displaying properly.    If I temporarily change the text styles that contain a yield warning symbol to another shx style, then purge, then save the drawing, close autocad and come back into the drawing, it fixes it.  But temporarily.  If I close the drawing a second time, and come back in, it may or may not still be fixed. It's hit and miss.  So I'm not sure what you'll see on your end.  I've also attached screen shots of what it looks like when it's displaying properly vs. not.  Regen makes no difference.
I should also add that this file serves as an xref to several files.  So not only does this base file have the issue, but so do the files it's xref'd into. I've found when I fix in this base file, I also have to go through that same process in each and every file it's x'ref'd into.  And, much like with the base file, the fix is only temporary.
Also, I've tried some other, unrelated, projects that use this linetype and they are all having the same issue since switching to this new computer.
