08-16-2017
01:38 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-16-2017
01:38 PM
Wipeout is out because can't be used in 3D model.
Only solution I can think is to use a new block embending your original block + a cylinder just larger. After inserting your block, you explode it and use cylinder to make a substraction to the pipe. With SOLIDHIST at 1 and Ctrl pressed when selecting around your block, you can chose Extrusion and your block to move them together. Perhaps, it's what you're already doing.
Here is link for Screencast : http://autode.sk/2uIZfnc
Olivier
Olivier Eckmann
