en respuesta a: Anonymous
I'm not using UCS on either drawing, both are using WCS. I looked a little closer and found out that the solid in the drawing I was copying to was skewed, not the solid I was copying. It was a different problem than what I thought. But now I'm not sure why the solid was skewed. It's basically an auger shaft with flights that I made with the sweep tool. The shaft and the flights are skewed ~.5 degrees from "flat" but nothing else on the drawing is. There's 8 different augers I've drawn like this and they all were skewed ~.5 degrees in the same way. I fixed them with 3d align, but its very strange.
