284 Vistas, 3 Respuestas
How to change Fabrication duct Database from Server to PC
Dear,
In our office for fabrication Duct now we are using database from server(Ex:F:/ACAD),but when we are going to site we could't access this server so we are coping this to USB and we are just just rename the drive name,then it will work.
Now i want to know that if we copy this database to C:/ it will work or not please advise.
or is there any comment to read this c drive to F drive please advice.
john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
Which application are you using? Is it possible within the application to remap to the database?
If not, when you plug in the USB drive, if you start Disk Mangement from the Windows Run field, you will see a lists of drives (including the USB). If you right-click on the USB, select Change Drive Letter and Paths... and select drive F:
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
john.vellek
HI @Anonymous,
I haven't seen another post from you on this issue.  After having re-read your post however, I wonder if you shouldn't go into your Disk Management utility and create a Virtual Drive.  This drive could have the same drive letter assigned to it as the server share and then you could put your database in it without issue.
John Vellek
