08-09-2017
06:27 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-09-2017
06:27 AM
Interesting...
Using 2018 here and running RECOVER on the 23MB drawing file uncovered only 3 errors, which were fixed. The drawing contains nearly 398,000 objects, including 6144 blocks.
After running RECOVER, I had to PURGE-all 61 times (my previous record was 23) to remove all the purge-able stuff, most of which was the orphaned DGN linetypes. After saving, the file size only went down about 50% to 10.6MB. (I expected more, so there may be some overly complex other "stuff" in there, probably in block definitions. Hatching may also be contributing.) I ran RECOVER on the purged and saved file and no errors were found. The drawing now has about 161,000 objects.
