08-02-2015
11:36 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-02-2015
11:36 PM
So your question was that you want to edit/modify the drawing files protected by someone else.
If this is the case, you have to ask the sender provide you a solution - give you a password or something that unlocks the files.
BTW occasionally some dwg files were set to "Read-only" in its "properties" when you received them by email. In this case you can untick the "Read-only" box and you will be happy.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
