BeKirra
en respuesta a: Anonymous
What you said - "...sometime client ask for cad drawing and change or edit it by themself."
Therefore, you can't protect your drawing files if you send them out.
Now many people convert DWG file into PDF format before sending out.
BTW AFAIK AutoCAD dwg files can be locked by password but it is not at a high protective level. - However this is not the option that you're looking for.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
