08-08-2017
05:31 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-08-2017
05:31 AM
"I suggest moving your data to a new file ASAP..."
Based on the file size (22+MB), I too suspected and confirmed the DGN Linetype "infestation". Unfortunately, moving the data to a new file will not resolve that, as the orphaned linetypes will go with the data and continue multiplying. Depending on which version of AutoCAD the OP is using, the solution will vary.
For pre-2015, this article may help: http://cadpanacea.com/wp/?p=512, or search the forums for "DGN Linetype Bloat".
If the OP is running 2015 or newer, I believe the PURGE command has been modified to deal with these objects.
