1420 Vistas, 4 Respuestas
Fatal Error when deleting hatch in AutoCAD
Please can someone help me?  I have a drawing that is predominantly raster, so the image file is embedded and has worked in the past.  I created a hatch inside a boundary in paper space and now every time i try to select that hatch, the program crashes.  I need to delete the hatch for a new revision of this drawing, but cannot.
I have purged the drawing, as well as run the AUDIT command, and the fatal error still comes every time I try to select the hatch.
I am currently running AUTOCAD 2017, on windows 10.  24 GB of ram, so the system is more than capable... there has to be a problem with the file, that I am not picking up on.
@Anonymous,
john.vellek has edited your subject line for clarity: Fatal Error
Alfred.NESWADBA
en respuesta a: Anonymous
Can you first start command _DELETE and select then the hatch to erase?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
HI @Anonymous,
Can you detach the raster images temporarily to see if it makes an difference?  Is it possible to attach the drawing file to a post so I can see if there are some other options too?
John Vellek
en respuesta a: Alfred.NESWADBA
Thank you alfred!  I feel really stupid for not having tried that first, but it worked.
braudpat
Hello
Just a few Infos !
1) I hope you have the SP1 on your ACAD 2017 ?
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-2017-service...
2) And the Update 1.2 that you can get from the "Autodesk Desktop Application" or from your Autodesk Account ...
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
