1017 Vistas, 15 Respuestas
Changing the “Precision” of “Linear Dimension” in the primary units...
I recently started experiencing an issue with my linear dimensions in Paper Space. I tried to adjust the Primary Units-Precision in the Properties to 1/16" because I needed it to be more precise than 1/4". Since trying to make this adjustment I have had continuous issues with the Dimensions changing from...for Example...5'-8" to 136'-0". This happens if I adjust anything in Model Space that is in a Viewport on the Layout. ALL of the dimensions on that specific layout will change. Any suggestions on how to fix this?
