en respuesta a: Alfred.NESWADBA
Thank you very much, I will try it out a little bit later.
@Alfred.NESWADBA wrote:
while you are in block-editor and use command _ATTDEF to define your attribute make sure the checkbox "Display value for block reference" is activated!
Look to the video which shows the complete workflow, I also attached the modified dwg-file.
HTH, - alfred -
