Kent1Cooper
en respuesta a: imadHabash
@imadHabash wrote:
Command: -CH CHANGE
Select objects: Specify opposite corner: 2 found
Select objects: Specify change point or [Properties]: p
Enter property to change [Color/Elev/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]: la
Enter new layer name <varies>: 0
Or, save yourself one step, and use the CHPROP command, which is like a collapsing together of the CHANGE command and its Properties option.
Kent Cooper, AIA
