408 Vistas, 1 Respuesta
problem on resizing excel sheet
As i am beginner, not sure any easy way to explain the issue. I am working on a autocad 2014, and having problem on resizing excel sheet.
i have a drawing contain linked Excel sheet, the problem is that when i adjust the size of the excel sheet it get damaged. i tried it many times but not able to make any adjustment related to size, it shows the link has been broken.
msudhakarcivil
en respuesta a: Anonymous
I faced this problem too. I just open the excel OLE by Rightclick > OLE < Open   (or)  OLEOPEN Command.
Then I simply copied the cells that I want and deleted the old OLE.
Please try that.
Sudhakar MuthuKrishnan
Please use "Accept as Solution" & give "Kudos" if this response helped you!
