Shaiki_
15311 Vistas, 3 Respuestas
Command to change layer of selected objects
Is there a command to change the layer of selected objects via the command line? I like how "clayer" allows you to set the current layer through the command line, but it would also be nice if I could change the layer of objects through the command line as well!
cadffm
en respuesta a: Shaiki_
Use AutoCAD help, press [F1]
change Layer command
The way for help yourself.
Solution:
command CHPROP or CHANGE
LAYCUR and others
HTH
Sebastian
imadHabash
>> Is there a command to change the layer of selected objects via the command line? <<
Yes you can by CHANGE command.
Command: -CH CHANGE
Select objects: Specify opposite corner: 2 found
Select objects: Specify change point or [Properties]: p
Enter property to change [Color/Elev/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]: la
Enter new layer name <varies>: 0
Imad Habash
Kent1Cooper
en respuesta a: imadHabash
@imadHabash wrote:
Command: -CH CHANGE
Or, save yourself one step, and use the CHPROP command, which is like a collapsing together of the CHANGE command and its Properties option.
Kent Cooper, AIA
