ChrisRS
en respuesta a: Anonymous
Try TEXTALIGN
If you set the options, TEXTALIGN will also clean up vertical spacing.
For sheet index and other numbered/keyed lists, I generally use tables. I set the cell alignments for the number/key column to Top Center and for the description column to Top Left. Using the "Top" alignments look good when the description wraps to multiple lines.
Christopher Stevens
