302 Vistas, 3 Respuestas
how to make these page numbers align with each other vertically?
I am creating an index using field command. I can't make them aligned just by hitting space key.
ChrisRS
en respuesta a: Anonymous
Try TEXTALIGN
If you set the options, TEXTALIGN will also clean up vertical spacing.
For sheet index and other numbered/keyed lists, I generally use tables. I set the cell alignments for the number/key column to Top Center and for the description column to Top Left. Using the "Top" alignments look good when the description wraps to multiple lines.
Christopher Stevens
john.vellek
Hi @Anonymous,
I believe that the kerning is determined by the font you select in creating your Text Style. If you want them to align you need to select a font with fixed character size such as MonoSPac821 BT.
I think this will improve the alignment for your index.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or @ChrisRS's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
