662 Vistas, 6 Respuestas
color problem in autocad 2016
my auto cad files is open in back ground brawn but i choose this color
and line i draw red in layer but it draw line blue
solve this problem
imadHabash
en respuesta a: Anonymous
try to disable hardware acceleration from 3Dconfig command.
Imad Habash
pendean
your PC mas more than one video card by chance?
And it's using the crappy intel-one instead of the better one?
en respuesta a: imadHabash
When i disable hardware .. autocad come solw and can't draw fast
But i found slove
When i make direct x from v 12 to v 9 it slove the problem
But why AutoCAD dosen't work with direct x 12 to
But i found slove
imadHabash
yes you're right .... in certain cases and depending to your station specs compatibility is needed. it's great to hear that you solve your issue.
Good Luck..
Imad Habash
john.vellek
Hi @Anonymous,
I have found the DirectX to be a problem sometimes. AutoCAD 2016 was developed prior to DirectX12 which is likely the root cause of this issue.  Can you tell me the exact OS, Graphics card make and model, and driver installed? I am curious to see if the card is incompatible with DirectX 12.
I have logged this with the QA team to see if they can provide me with feedback.
John Vellek
