DaveArnold1619
696 Vistas, 7 Respuestas
no grips on images with imageframe set to on.
Saved file at work where grips were present and working. Got home and opened file now can't get grips to show. Simple setting i'm missing?
en respuesta a: DaveArnold1619
Did you already try this?
DaveArnold1619
en respuesta a: Anonymous
FRAME settings has no affect ........
user181
Is your GRIPS variable set to 0? That would hide grips and setting it to 1 or 2 will show the grips.
DaveArnold1619
Opened file in 2007 version, worked fine. Opened in 2017 version and good there too. I worked with file using 2017 format, then saved back to 2013 for use at work. Thanks for your suggestions. Not sure what is set different between my 2013 at work and at home but will save a script today to see if that works tonight. Have a great day.
user181
The GRIPS variable is stored in the computer registry and not in the drawing file so the setting can be different from computer to computer. As I stated in previous comment make sure GRIPS is set to 1 or 2 on the computer you are not seeing the grips.
DaveArnold1619
en respuesta a: user181
FRAMES & GRIPS settings had no affect. Guiño Will work on project in 2017, so no longer a problem. Thanks.
