08-02-2017
09:09 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-02-2017
09:09 AM
if you have these toolbars defined in a separate CUIX-file you can start command _MENULOAD and add your cuix as partial menu.
Then use command _CUI to modify your workspace ... and activate your toolbars to the current workspace.
If you don't have a separte CUIX-file (which I would see as better solution) you can use command _CUI and the "transfer" option (top left to switch to "transfer") and copy/move your toolbar from your old customized menu to the current one (or a new one loaded as partial menu
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
