406 Vistas, 2 Respuestas
Adding custom toolbar to new Acad install
I have custom toolbars from Acad 2017 and older.  I want to add them to the toolbar selection so I can add them to my custom cui.
Alfred.NESWADBA
en respuesta a: Anonymous
if you have these toolbars defined in a separate CUIX-file you can start command _MENULOAD and add your cuix as partial menu.
Then use command _CUI to modify your workspace ... and activate your toolbars to the current workspace.
If you don't have a separte CUIX-file (which I would see as better solution) you can use command _CUI and the "transfer" option (top left to switch to "transfer") and copy/move your toolbar from your old customized menu to the current one (or a new one loaded as partial menu :cara_guiñando_un_ojo: ))
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
These are great tips, but before I can do that, I need to get the custom toolbars to show in the .cui to move or transfer.
