350 Vistas, 4 Respuestas
Mesh to Solid
I need to convert the mesh to a 3D solid so I can export it to a .stl
Please help
Etiquetas (3)
imadHabash
en respuesta a: Anonymous
i suggest to use Convtosolid command. and if not work from the first time use Meshsmooth first then use Convtosolid.
Good Luck..
Imad Habash
en respuesta a: imadHabash
That doesn't work.  It's too complex.  I tried using the Polyhedral Mesh To Solid add on.  It worked for everything but the seat and seatback.
JDMather
Do you plan on 3D printing this?
If yes, what is the build envelope for your printer?
en respuesta a: JDMather
No. I am importing it into Blender to render.
