en respuesta a: Anonymous
I figured out a solution: publishing through the sheet set manager instead of the PUBLISH command!
In the sheet set manager, I created a new page setup specifying my third party plotter as well as all the other required page setup settings. Sheet set publish options is set to multi-sheet file. Publish using page setup override/[the new page setup I just created] created exactly what I wanted: a multi-sheet pdf that graphically matches other pdfs created by the desired plotter.
Thanks everyone for your help!
