Alfred.NESWADBA
en respuesta a: Anonymous
>> I just found out I can export it as a windows metafile
WMF would be one option, but when I use _COPYCLIP or _COPYBASE in AutoCAD and select objects, then set my focus to MS-Word and just press <CTRL><V> for paste I see the breaks.
Anyway, good to know you have found a way that works for you! :cara_guiñando_un_ojo:
>> The problem is sometimes it works and sometimes it doesn't. Why is this?
>> is it because of the layers? Is it a setup of the lines below?
The multiline-object needs to be above the other lines. You can use command _DRAWORDER to send objects to back or to front.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
