rkmcswain
en respuesta a: Anonymous
One way:
Use a standard template that contains all of your layers in both files (before getting started).
Let's say you have 100 layers, but only have geometry on 10 of them in File "A". Freeze the other 90 layers before Xref'ing A into B.
When you xref A into B, those 90 layers will be frozen also. As long as VISRETAIN = 1, they will stay frozen, even when you thaw them in "A", and reload the xref.
Then you can thaw them in "B" as desired.
