07-24-2017
10:44 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-24-2017
10:44 AM
Hi @Anonymous,
Once you switch to your layout, double-click in the viewport to enter modelspace. No you can zoom a window around your model to the approximate area you want to display. Then using the scale list in the bar at the bottom (right) you can set the scale you need. If you want full size, then select 1:1 as Imad suggests. If that does not fit you can then explore other scales such as 1:10, 1:20, 1:50, etc.
Please let me know if you require additional assistance with this issue. If you would like to attach your file to a post I can help you set the scale too.
John Vellek
