07-24-2017
05:32 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-24-2017
05:32 AM
It appears as if you are trying to blockout the pipe as you move the valve in order to make it appear as though there is a break in the pipe at the valve. While a wipeout works for that in 2D, you are out of luck for 3D without some very heavy programming.
Your solutions are:
1. Break the pipe at the valve, leaving the cylinders as cylinders so they are easy to grip drag the lengths.
2. Invest in a real pipe modeling application like Plant 3D that will automate (somewhat) the control of valve locations.
3. Have someone write an alternative to Plant 3D (that will be expensive)
