07-23-2017
02:52 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-23-2017
02:52 AM
>> It seems to be some kind of autocomplete that it thinks that's what I want
>> to type. I don't understand why it fills out FASTSEL
E.g. if you define in ACAD.PGP the F key to start _FASTSEL, then it's a definition that someone did on your system or an application might have defined.
If you think it's an autocomplete setting (which might be because autocomplete sees this command as most used and so orders it on the top), just disable autocomplete and see what is then called by <F><ENTER>.
If again _FASTSEL is selected then look to your ACAD.PGP file and see what is defined for <F>
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
