07-22-2017
08:22 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-22-2017
08:22 AM
Not sure what you're attempting to accomplish, but in most cases the valve breaks the line in which it is inserted with either a welded joint, a flange or a coupling, all of which need to be indicated on the drawing. If you're just trying to make it easier to model so you don't have to adjust the pipe when the valve moves, I think you're out of luck as most of the work-arounds discussed so far will fail to produce the right view when you go to drawing production.
If you leave the pipe cylinders alone (no slicing) they are quite easy to change length by just grabbing a grip and dragging.
