07-21-2017
10:27 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-21-2017
10:27 AM
If you have running Osnaps set then you will get the points on or off of geometry. With running Osnaps off and you explicitly use an Osnap, like ENDpoint, then if you aren't on geometry and pick you won't get the errant selection off of the geometry.
A more radical solution is to set your running Osnaps and set OSNAPOVERRIDE to 1 and only picks with an Osnap will work.
GrantsPirate
Piping and Mech. Designer![]()
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
