leothebuilder
en respuesta a: Anonymous
There could be a few things that cause bloated file sizes.
First I would check for phantom linetypes and text styles.
Just enter LTYPE at the command line and see if you have a bunch of linetypes that should not be there.
You can also run the OVERKILL command to get rid of lines that are on top of each other.
Use WBLOCK as a way to purge the file.
