07-20-2017
11:20 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-20-2017
11:20 PM
Good day
You can use the shaded option, it seems to project the material through:
- Select a created view
- On the contextual ribbon select the edit view command
- On the new contextual ribbon select the second dropdown
- Select the shaded option
See attached image for reference.
Those are the only 4 options available. If this does not give you what you need then you will need to use viewports
Regards
Marnus van Staden
Technical consultant & Civil 3D support Specialist
Prokon Software Consultants
Kind Regards
Marnus van Staden
N.DIP Civil Engineering | Senior Technical Specialist
Autodesk Trainer | Draughting Consultant
________________________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
Apex Solutions Youtube Channel
