- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
If this tool does not work with text of dimension, then why there is this point (dimension or leader text) in search options?
Yes, that's misleading. They shouldn't lump them together into one category, because it can find things in [further misleading part:] Multi-Leader text. [Plain Leaders get just Mtext when you give them some content. The Leader is affiliated with the Mtext, not the other way around -- that is, you can move the Mtext and the Leader adjusts to follow, but if you grip-edit the Leader, the Mtext doesn't follow. So they should call the Leader an "Mtext Leader," and not refer to the Mtext as "Leader text."]
Mleader text is, as with Text/Mtext/Attributes/override-Dimension-text, actual textual content, and not a conversion of a numerical value, which is why FIND can work with it. But for some reason it's not contained in a (1 . "...") entry in entity data as with all the other kinds, but a (304 . "...") entry.
