1598 Vistas, 5 Respuestas
Annotative Mleader with Block incorrect text scale
I am having an issue with the scaling of an mleader block inside AutoCAD 2016.
We are implementing using annotation scales for all text, dimensions, leaders, etc. All text, even Mleader text scales properly to the selected annotation scale.
However I have created an Mleader with a block (instead of Mtext) and inside the block (Which is a circle) there is text. Just a single letter to reference a detail. The letter inside the circle is not the correct text height. It is coming in 25% smaller than the rest of the text in the drawing. I have double checked everything I can think of. Everything is set to annotative and I have the correct text style active.
Also, if I explode the Mleader and double click the block (circle with text) and view the text options I see that the text style is correct but the height (which should match my annotative text height) is 25% smaller than what the text height should be.
For reference I am using an annotative scale of 1/4" = 1'-0" and my annotative paper text height is set to 1/8". Therefore the actual text height should be 6". When I explode the Mleader and check the text options, despite the text style being set correctly, it shows the height as 4 1/2".
I have attached a couple of pictures to help illustrate. One is showing the exploded block with incorrect text height. The other is showing the properties of the text style used in the block.
At this point I am lost.
Any solutions would be greatly appreciated.
Sincerely,
Billy
pendean
en respuesta a: Anonymous
Post the DWG file please.
en respuesta a: pendean
See attached DWG.
Thank you.
pendean
Your single letter A is 6", your block's A is 4.5"
Correct. This is my problem. The text in the block should match my active text style, which it does not.
I need the text in the block to be 6" (1/8" paper height) like the rest of my text. I could simply set the scale of the block to 1.25 (see below), which I have done for now, but I am trying to figure out why it is different from the rest of the text in the drawing. The convenience of using annotative objects should alleviate this problem altogether.
mbriegel
The issue is the block itself. If you insert the _TagCircle block which is what the leader uses and then use the block editor, you will find that the text is not annotative and the text height is set to .0938 which is .7504% of the .125" height you wanted (or the 25% that you referred to). I have not tried to change the text to annotative in the block but not sure how the circle would look around the text with the various scales but it would be easy enough to test. Hope this helps.
