07-18-2017
07:00 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-18-2017
07:00 AM
Hi @Anonymous,
That is the setting in AutoCAD that should control this behavior. Since it did not seem to make a difference, I suggest taking a closer look at the Windows Printer driver and how you are actually sending the print job to the printer.
What kind of hardware did you just install? Which driver version are you using? Is the printer driver installed locally or is it pushed from a server? Do you print to a print server or are you sending the job straight to the IP address of the printer?
All of these details can affect how your print job comes out without being interrupted.
John Vellek
