Alfred.NESWADBA
en respuesta a: Anonymous
>> The scale is 1:1
Well, it's strange as with 1:1 the lineweights should appear on the paper in the same size it is defined eihter for the layer of the object, or the object itself or the CTB/STB if there is any used to overwrite the lineweights.
Can you please save the drawing with a different file-name, then run command _ETRANSMIT to create a zip-file from your drawing with referenced files.
Please upload that ZIP as well as the PDF created for the same paperformat as the plotter is set and having too thick lines.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
